Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - carb spacer plate
Old 07-27-2008, 09:08 AM
red65mustang red65mustang is offline
are you tuning for better at the strip or better on the street atomization???
here's a good spacers explaination article....
http://www.gnetworks.com/v4files/bar...h%20images.pdf
and there is another good article in the Knowledge Base link at the top of the page.....
yes, your present 1/2" open spacer may well be adding a few more WOT peak HP ponies...."but".... at street rpms it is making the RPM dual plane intake behave as a open plenum design because there is no divider wall at the carb bottem...
on a intake stroke the piston is trying to pull a vacuum to make a strong carb Hg (good velocity for excellent atomization) signal from all 8 of the intake runners cubic inches of area due to no divider instead of just 4 runners worth of area....
(and worse it's 1/2 the carb signal at the carb because it is pulling from both primaries)
if your looking for better street driving performance I'd remove the 1/2" open spacer and test drive it....the "high rise" RPM intake already has a plenty tall carb base to plenum bottem distance...
