Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - carb spacer plate
Old 07-27-2008, 10:47 AM
vetteman vetteman is offline
Thanks for the feedback. Although the car does run well, I thought it could use a little tweaking off idle. Heat soak was the reason for the 1/2" spacer, and I did do some checking about adding another 1/2" to an already "high" intake, and came to a conclusion a 1/2" wouldn't really affect it that much. So I guess if i'm bored, i'll experiment with the four hole plate I have.
