-   -   carb spacer plate (http://www.hotrodders.com/forum/carb-spacer-plate-142597.html)
vetteman 07-27-2008 05:46 AM
carb spacer plate
I have this plate, and was wondering if it would help atomize the fuel a little better at low to mid rpm's. I have a performer rpm, Holley 650HP, 1/2" open carb spacer. This motor was dyno tuned, but I never thought about trying this plate. This motor is in a 64 vette, 4-sp, 327-350. Any thoughts?http://i111.photobucket.com/albums/n...4/100_0776.jpg
dawg 07-27-2008 07:31 AM
4 hole spacer plates help atomize the fuel/air in otherwise big manifolds.
helps get rid of the bog /hesitation off the line.
but judging from the pic that spacer is too thin.
at least 1" to notice a difference.
malc 07-27-2008 08:14 AM
It looks to be more of a gasket.
Stay with an open spacer, one inch better.
I went to a one inch open after a four hole and the difference was
noticeable immediately with the idle.
More torquey as both banks can call upon the whole carb.
Take a lookat this from CarJunkies may take awhile to load.
red65mustang 07-27-2008 09:08 AM
are you tuning for better at the strip or better on the street atomization???
here's a good spacers explaination article....
http://www.gnetworks.com/v4files/bar...h%20images.pdf
and there is another good article in the Knowledge Base link at the top of the page.....
yes, your present 1/2" open spacer may well be adding a few more WOT peak HP ponies...."but".... at street rpms it is making the RPM dual plane intake behave as a open plenum design because there is no divider wall at the carb bottem...
on a intake stroke the piston is trying to pull a vacuum to make a strong carb Hg (good velocity for excellent atomization) signal from all 8 of the intake runners cubic inches of area due to no divider instead of just 4 runners worth of area....
(and worse it's 1/2 the carb signal at the carb because it is pulling from both primaries)
if your looking for better street driving performance I'd remove the 1/2" open spacer and test drive it....the "high rise" RPM intake already has a plenty tall carb base to plenum bottem distance...
vetteman 07-27-2008 10:47 AM
Thanks for the feedback. Although the car does run well, I thought it could use a little tweaking off idle. Heat soak was the reason for the 1/2" spacer, and I did do some checking about adding another 1/2" to an already "high" intake, and came to a conclusion a 1/2" wouldn't really affect it that much. So I guess if i'm bored, i'll experiment with the four hole plate I have.
red65mustang 07-27-2008 11:14 AM
you can buy a oem approx 3/8" thick 4 hole insulating carb gasket at your local parts store for about $10?....
the Edelbrock 3/8" insulator 4 hole gasket is about $14?
vetteman 07-27-2008 11:57 AM
Maybe I overlooked those, but at the time I believe the thinnest,in phenolic I could find was 1/2". 4150 style. The purpose for the spacer was for heat soak, not tuning. But I believe,except for upper rpm's, the four hole insulator/spacer would be preferable for street. Although with a 4-sp, I can work with the rpm's to overcome the low rpm glitch.
