Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Carb Spacer Question
Old 01-14-2003, 06:23 PM
irocz8868's Avatar
irocz8868 irocz8868 is offline
Post
i like the open spacer. it all depends on what you are looking for. fuel mileage or horsepower. with the open spacer there is no restriction. the more air you can feed the engine the more fuel you can feed. keeping in mind how you adjust your air and fuel mixture will be the outcome of your overall engine performance. if problems occure while adjusting the carb try power timing the engine first.
