Carb spacer question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2005, 01:11 AM
Gametech's Avatar
New Member
I have a Wieand 8004 dual plane intake on a small block Chevy. I'm going to be putting an Edelbrock #1406 carb on it, with a 1" four hole spacer between the two. I know the diameter of the Holley ports are slightly larger than that of an Edelbrock. My question is, would it hurt to use a four hole spacer designed for Holley, under an Edelbrock carb? My thinking is that you would use an Edelbrock gasket directly under the carb, and a Holley gasket under the spacer. (Edelbrock - 1.467" / Holley - 1.75") Or should I stick with a spacer that that has the 1.467" diameter holes to match the carb? Thanks.
Old 05-21-2005, 01:15 AM
New Member
Match the carb...or else run open design if your intake is open. If not match it correctly. If you already have it and can't return it possible machine it out a little but make sure the holes line up.
Old 05-21-2005, 01:53 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
intake
I am not familiar with your model of intake. Edelbrock performer RPM has a divided plenum but the Airgap/RPM has the plenum cut down about a 1/2". This allows the Airgap to take advantage of the divided plenum and Single plane designs. If I was going to put a spacer in, I would opt for an open spacer to take advantage of the Single plane design as well as the divided plane you are using.
Old 05-21-2005, 08:02 AM
Gametech,
I would recommend trying to find a 4 hole spacer that matches the bore pattern of the Edelbrock carb.
I bought a Holley spacer for mine and didn't like the way the bores on the holley spacer were so I made my own on a CNC Mill.
It just doesn't make any sense to me to put a 4 Hole spacer in between when the Holley pattern is larger especially on the primary's.
If I happen across one I will let you know.
Tmod
Old 05-21-2005, 02:44 PM
Gametech's Avatar
New Member
Ok, I'll stick with the Edelbrock diameter when I buy one. My original thoughts were, "Since the Holley spacer had a slighty larger diameter, there wouldn't be a restriction... as compared to if I was trying to go the other way around." (Holley carb on top of an Edelbrock designed spacer) Thanks for steering me in the right direction. I remember Pep Boys had a Phenolic 4 hole spacer (1"), will try to stop by there tomorrow and check it out.
Old 05-21-2005, 10:04 PM
New Member
sorry I was confused. I thought you were putting smaller bores under a larger bored carb, not vice versa. It should work fine assuming it lines up symmetrically.
Spacer between carb and intake manifold?... doc_rage Hotrodding Basics 2 02-06-2004 07:40 PM
302 Carb question Thuggishruggish3000 Engine 5 01-07-2004 08:16 PM
carb question mettler Engine 2 09-30-2003 07:45 PM
1 inch carb spacer black66 Engine 6 09-04-2003 06:21 AM
Q Jet carb question motoxracer Engine 2 07-20-2003 11:28 PM
