Carb spacers
I currently have a 1" open spacer and the motor seems to like it - but only in third gear I do notice that the car accelerates slower than before with a 3/8" open spacer. Maybe because not enough velocity to pull the required fuel needed at WOT in third gear with the taller open spacer? I am wondering would a 1" four-hole spacer on top of the 1" open spacer help this problem?
OK, here's my take on spacers. It all depends on the rpm range in which the motor will operate and the cam you're using. If using a 180* dual plane manifold, you're asking the motor to operate from idle to about 5,000 and it will generally make good power in that range because any one cylinder only "sees" 1/2 of the total volume of the manifold and therefore can suck a vacuum and generate good velocity to fill the cylinder better than if you used a 360* single plane manifold. If operating in a range of maybe 2,000 to 6,500, the 180* manifold will choke the motor, so the 360* manifold might be a better choice to make power in the upper rpm range.
When you add an open spacer to a 180* manifold, you effectively turn the manifold into a 360* manifold, because now, any one cylinder "sees" the entire volume of the manifold just as it would if you started with a 360* manifold in the first place. Low rpm response will suffer while upper rpm power will pick up. You may think the car is faster overall because it picks up at higher rpm's, but I'll bet that if you had the car on a dyno, you'd see that the power under curve is lower at rpm's less than where the motor begins to breathe better. All this assumes a stock to near-stock converter. If you were to use a looser converter, then of course the motor would bypass the soggy lower rpm range and make more power under curve, resulting in a faster car. I hope I'm explaining this well enough to understand. Let me put it this way: Let's call (no spacer) 180* power "X". If you add an open spacer, low rpm power will be down due to lower vacuum and resultantly lower velocity and less cylinder filling. Let's say at 2,000, you're down X minus 30 hp. At 3,000, you're down X minus 20 hp. At 4,000, you're down X minus 10 hp. At 5,000, it's a wash. At 6,000, your up X plus 10 hp. At 6,500, you're up 15 hp. It should be easy to see that you're applying more power under curve throughout the lower rpm range, more than could be made up for in the upper range. I realize this is not very scientific and is just a supposition on my part, but it all makes sense to me. I hope it makes sense to the rest of you. I would welcome alternate points of view. |
Check the Knowledge Base for tuning with spacer's,
http://www.hotrodders.com/kb/carburetor-articles-2
Luv the smell of NITRO in the morning. |
Right on - thanks for your advice to all. I put a 1" four-hole spacer on top of my 7/8" open spacer on top of my RPM air-gap manifold and it is what the doctor ordered. The car rips! It pulls more aggresively at take off and rips on the high end! Last week I put on a 3/8" open spacer on top of the manifold and woke up my motor - turning my dual plane into a single plane kinda. My operating range is around 3000-6000rpm. Trans has a 2600rpm converter. Then I added another 1/2" open spacer on top of that yesterday - and I noticed that the motor was pulling less. So now, today, after adding a 1" four-hole spacer on top of all of that it pulls better than ever before! Gets horrible gas mileage, though.
| Too much carb? | KNanthrup | Engine | 5 | 09-03-2005 06:47 PM |
| 25 Year-old Carb, rebuild or trash? | Arcuden | Engine | 6 | 07-31-2005 08:42 PM |
| Holley carb has me at wit's end | cool rockin daddy | Engine | 23 | 06-02-2005 02:38 PM |
| What Came first Chicken or the Egg, or Carb Adj vs Timing | riesman20 | Engine | 19 | 07-18-2004 10:26 PM |
| Four hole carb spacers | stinky jinx | Engine | 5 | 05-29-2004 10:21 AM |
