carb spacers - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2008, 10:59 PM
carb spacers
what is the point of carb spacers do they help or not just wondering what the benifit is thanks in advance
Old 07-12-2008, 11:10 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
I have seen dyno tests that reported gains in using some carb spacers. Better atomization and flow. Some help insulate the carb from intake heat.
Some smooth the flow below the carb bottom.
Some increase plenum volume just by adding height.
Open spacers allow both sides of the manifold to pull from the whole carb, kind of like those dual plane intakes with part of the center divider cut out.
Carbs are too low to the manifold floor and make the mixture turn too sharp into the runners, causing gas to drop out of the air mix. Raising the carb often helps this.
Every situation is different. Spacers are a try and see proposition.
Old 07-12-2008, 11:39 PM
malc's Avatar
Born To Be Mild
I had great results going from a 1" four hole spacer to a 1" open.
Check out this CarJunkieTV intake shootout.
Old 07-13-2008, 07:10 AM
dawg's Avatar
NAVY VETERAN
one thing to remember if carb spacer is over 1" you gotta jet up 1 to 2 jet sizes higher.
Old 07-13-2008, 07:18 AM
frankenvette's Avatar
Go ahead kid squeeze the wheez
Awesome malc, thanks for the link!
Old 07-13-2008, 08:35 AM
thanks
thanks for the links great explanation
steve
Old 07-13-2008, 08:46 AM
302 Z28's Avatar
Carb spacers also increase intake charge velocity.
Vince
Carb spacers Sixtyninemercury Engine 4 04-24-2008 09:52 PM
Too much carb? KNanthrup Engine 5 09-03-2005 06:47 PM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
What Came first Chicken or the Egg, or Carb Adj vs Timing riesman20 Engine 19 07-18-2004 10:26 PM
Four hole carb spacers stinky jinx Engine 5 05-29-2004 10:21 AM
