Carb spacers part 2 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2012, 01:43 PM
Last journal entry: Photos
Carb spacers part 2
Found some good Slee posts from last year on carb spacers. But I have two interesting questions. Re: notched squarebore dual planes (rpm air-gap). If I use a divided spacer, which would work better? To fill in the manifold notch and re-notch the spacers divider so it stays up at the top? What about the manifolds notch when a 4 hole spacer is used? It'd be sitting down 2" down. I wonder if a notch with a 2" spacer is creating a problem?
Old 02-15-2012, 03:44 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
On a 180 degree intake the notch equalizes vacuum pulses between the 2 sides of the plenum! its needed to create equal mixture between the 2 sides. (simple explanation) But why install the spacer are you trying to compensate for getting the wrong intake? It was designed to operate at a certain RPM range. The only problem I ever saw in these intakes was carb venturies
Old 02-15-2012, 03:45 PM
On a 180 degree intake the notch equalizes vacuum pulses between the 2 sides of the plenum! its needed to create equal mixture between the 2 sides. (simple explanation) But why install the spacer are you trying to compensate for getting the wrong intake? It was designed to operate at a certain RPM range. The only problem I ever saw in these intakes was carb venturie's frosting in this northern climate even on cool summer early mornings !
Jester
I hit the wrong button & sent this early sorry about that!
Old 02-15-2012, 06:26 PM
Reason is to implement my sealed cold air intake system to the cowl hood. I tried to extend the air cleaner with a stack before and ran into low pressure level problems. Anyway it may help a little as an added feature in throttle response, etc.
Old 02-16-2012, 07:26 PM
The notch shouldn't matter with short spacers but the taller the spacer the further the intake air and fuel has to travel to reach the cylinders and creates a hesitation when throttle is applied. it also has a tendency to cause a reversion of the incoming fuel air mixture from the carb hitting the air fuel mixture in the intake and bouncing back ( simple explanation). the 4 hole spacer alleviates a lot of reversion problems and keeps the velocity of the incoming charge up and a better fuel air mixture.
Can you make an air box coming off the carb that will seal to your hood with your air cleaner mounted inside it?
Jester
Old 02-17-2012, 08:33 PM
hi jester. I just made a sheetmetal tube that goes from the carb to the air cleaner base. Its about 3" tall. I just went from a 3" tall filter to a 4" in case that was a supply problem. I can see the filter now from the drivers seat. Its only a 2" cowl. The factory perforations on the hood were really a limitation also so I cut them out and installed window screen. Anyway, I wonder if that stack tube I made will cause any flow/pressure problems. I think a V-shaped one would work better, but I don't know. I took the carb spacer out.
Old 02-17-2012, 09:20 PM
Years ago to place a scoop or air induction we used to tape light yarn to the hood and windshield and at speed see what the air column was doing. A lot of scoops actually are installed wrong and the air column flows away creating a low pressure area around the scoop. You might look silly with yarn on your car going down the road LOL but you dont have an air tunnel and smoke!
Jester
Carb spacers, which to use Overdriv Engine 4 11-05-2009 11:15 AM
Carb spacers? Scotto Hotrodding Basics 6 01-13-2009 01:34 PM
carb spacers hdscooters Engine 7 07-13-2008 09:46 AM
Carb spacers Sixtyninemercury Engine 4 04-24-2008 10:52 PM
carb spacers runn141 Engine 5 02-16-2008 07:09 PM
