-   -   Carb spacers, which to use (http://www.hotrodders.com/forum/carb-spacers-use-167862.html)
Overdriv 11-04-2009 11:15 AM
The carb linkage on the rear 4779 Holley hits the carb adapter on our 6-71 blower setup on a BBC. We will have to use a spacer of at least 1/4" but will probably use a 1/2" spacer.
My question is is there any advantages to using a open spacer or a 4-hole spacer?
BogiesAnnex1 11-04-2009 11:24 AM
Open! A blower and it's manifold replaces and overcomes the issues that drive un-supercharged engines into 180 degree dual plane manifolds. So individual throttle hole spacers aren't necessary.
Bogie
dawg 11-04-2009 11:33 AM
heres a good article explaining the spacers
http://www.gnetworks.com/v4files/bar...h%20images.pdf
Overdriv 11-05-2009 10:04 AM
Thanks guys, kinda what I thought but wanted some other opinions.
ap72 11-05-2009 10:15 AM
4 hole tapered into open- better carb signal. But when you only have a half inch to work with there won't be that much of a difference.
