Carb spacers, which to use - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2009, 11:15 AM
Overdriv's Avatar
The carb linkage on the rear 4779 Holley hits the carb adapter on our 6-71 blower setup on a BBC. We will have to use a spacer of at least 1/4" but will probably use a 1/2" spacer.
My question is is there any advantages to using a open spacer or a 4-hole spacer?
Old 11-04-2009, 11:24 AM
Open! A blower and it's manifold replaces and overcomes the issues that drive un-supercharged engines into 180 degree dual plane manifolds. So individual throttle hole spacers aren't necessary.
Bogie
Old 11-04-2009, 11:33 AM
dawg's Avatar
NAVY VETERAN
heres a good article explaining the spacers
http://www.gnetworks.com/v4files/bar...h%20images.pdf
Old 11-05-2009, 10:04 AM
Overdriv's Avatar
Thanks guys, kinda what I thought but wanted some other opinions.
Old 11-05-2009, 10:15 AM
Banned
4 hole tapered into open- better carb signal. But when you only have a half inch to work with there won't be that much of a difference.
Quadrajet Carb??????? zbhover Engine 15 08-26-2010 08:57 AM
carb spacers hdscooters Engine 7 07-13-2008 08:46 AM
Carb spacers Sixtyninemercury Engine 4 04-24-2008 09:52 PM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
Four hole carb spacers stinky jinx Engine 5 05-29-2004 10:21 AM
