Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - carb stumble under medium accelation
Old 10-02-2009, 05:32 AM
dawg's Avatar
dawg dawg is offline
NAVY VETERAN
a huge vacum leak would cause car to stall out when putting in gear.
if you got a power brake booster disconnect and plug vacum line if it still runs when shifting into gear then diaphram in the booster is blown.
also in automatics if the modulator is blown youll get same symptoms.
