carb stumble under medium accelation - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-06-2009, 08:59 AM
sqzbox's Avatar
My pipes are my music
Check your using the right gasket between the metering block and the body.
one has an open area above the power valve that uses a small O ring gasket.
that that makes up the difference in the recess.
One has no open area with a small hole that seals to the body for a flush mount. This is the accelerator pump transfer hole.
Use the wrong one and your going to have problems/flooding at idle.
This is one problem with universal kit's to rebuild several different models, it's easy to get the wrong parts or gaskets put in. This is why they say in the inst. to compare closely with the part/gasket your removing. Failure to get the right gasket in there will suck fuel out of the accelerator pump reservoir into the area behind the power valve. That will eat up the diaphragm on the power valve over time. Now, with that vacuum area full of fuel, the vacuum port that feeds the signal to the power valve will be sucking fuel also causing an over rich idle condition.
  #17 (permalink)
Old 10-06-2009, 10:15 PM
ok i checked today and i am for sure using the correct one
  #18 (permalink)
Old 10-06-2009, 10:44 PM
sqzbox's Avatar
And the PCV valve?
  #19 (permalink)
Old 10-06-2009, 11:20 PM
this car doesnt have a pcv valve (positive crankcase vent) if thts what you mean
  #20 (permalink)
Old 10-07-2009, 06:48 AM
sqzbox's Avatar
So, you have "open" breater cap's on the valve covers? or a breather hose going to the air cleaner?
  #21 (permalink)
Old 10-07-2009, 10:57 AM
yes i have a breather cap on the valve cover
  #22 (permalink)
Old 10-07-2009, 04:11 PM
i checked the metering blocks and they dont seem to be warped. i did fail to mention that i have tryed 2 different carbs one 4150 custom and a new out of box 4150 street and both had the same problems. i have disconnected the brake booster hose capping of the port and till has the problem.
Quadrajet Carb??????? zbhover Engine 15 08-26-2010 08:57 AM
modifying that too rich edelbrock 1405 carb? TVR383 Engine 23 12-03-2009 09:19 PM
Cleaning Carb Question oldcarguy36 Engine 17 03-04-2006 02:10 PM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
Need some pointers on Holley carb crshrmn3 Engine 2 02-08-2003 11:22 PM
