Carb Suggestions - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2005, 08:35 PM
New Member
Carb Suggestions
Not a "hot rod" but my daily driver.
81 chevy K-10, new GM 350 crate motor edelbrock performer intake, headers, dual exhaust. Current carb is an edelbrock performer #1405 it worked good on the old 305 but I think I can do better on the new motor.
Been looking/thinking Holley, demon, Q-jet
Any suggestions??? Like I said, daily driver, work truck, does some 4 wheelin' but mostly to get to and from work sites nothing extreme. It does tow a 4400# travel trailer on occassion.
Thanks
Old 11-05-2005, 09:12 PM
MI2600's Avatar
Member# 3287
My $.02 would be to stick with the Edelbrock unless it's a fudball giving you trouble. Many believe that a Holley will give them instant massive improvement and are disappointed. That 1405 is a nice solid carb and easy to work on if necessary.
Old 11-05-2005, 10:03 PM
New Member
The edekbrock is a good carb for it's intended use. I daily drive in elevations ranging 3000 to 8000ft sea level. Took me 2 weeks to get it adjusted when it was on the 305 so it ran ok all the time. Having to start over again really does not appeal to me not to mention I don't have 2 spare hours much less weeks right now. Last time the final combination was no where near to being what the book said or what edelbrock suggested so it is all trail and error. VERY time consuming.
Old 11-07-2005, 03:24 PM
2NDXRND's Avatar
Catherine Bell digs me........
Sounds to me like fuel injection would be perfect for you. Getting ANY carb dialed in in those elevation extremes would be tough.
I'm running a 1406 on a mild 351 W, and it was "plug and play"........ of course, I dont have any changes in elevation like you do.
Look at the Edelbrock and Holley F.I. systems. Pricey, but nice. Good luck whatever you decide!
Old 11-07-2005, 03:46 PM
stepside454's Avatar
I think Id use a Q-jet personally
Old 11-07-2005, 04:11 PM
steve t's Avatar
ex biker, now hotrodder
if you have a spread bore intake you will need a spread bore carb, unless you use a adapter
Old 11-07-2005, 04:25 PM
The performer intake accepts both square & spread bore applications
Old 11-07-2005, 06:53 PM
1982 SS's Avatar
Flamethrower
Last journal entry: More Cooling fan pictures.
The Performer does accept both style of flanges.
I woud use a Q-jet. It would be nice if you could find one of the 1900 series of Edelbrock Q-jets on a shelf somewhere. I have a 1910 and I have to do a little tuning berfore next season (playing with the secondaries). Otherwise a rebuilt Q-jet would be nice. I would contact a company like Jet and inquire about jetting for your elevation. If you go junkyarding for a Q-jet and you happen to find a bunch, pull them apart and take the primary jets and rods, the secondary rod hanger and the secondary rods. All nice parts to have for tuning. plus pulling a few apart will show you what you are up against when you rebuild your keeper.
Old 11-08-2005, 05:36 AM
New Member
Appreciate all the help folks.
Still looking though I have managed to get the edelbrock running to about 95% PERFECT still have a little playing to do to see if I can get it better still.
Old 11-08-2005, 07:18 AM
kringold's Avatar
ATA Welding Technology
Last wiki edit: How to rebuild an engine Last photo:
I bought my Rochester Q-Jet from this guy for under $200. You might want to check him out.
The Carburetor Doctor
modifying that too rich edelbrock 1405 carb? TVR383 Engine 23 12-03-2009 09:19 PM
Any problems spraying carb cleaner in my carb while its on the motor? batman09 Engine 11 11-29-2005 07:49 AM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
Where can I find this carb? (QJet) 78SilverShark Engine 7 08-14-2003 03:07 PM
rochester 4 jet carb, rich Walker Engine 2 07-13-2003 09:42 AM
