carb surges in drive - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2007, 09:20 AM
i have a quadjet that surges when i put it in drive. i recently put a new 350 motor in with vodoo cam port and polished 202 160 882 heads headers and intake and now when i try to adjust the airfuel mixture no matter if i try screwin in or out it still surges. it runs smooth in park though. the carb was on my 305 before and it had a eldebrock performer cam, intake and headers and did not surge when on that motor. does anyone know maybe why i cant' get the get it to run smooth in drive too.
Old 07-15-2007, 09:39 AM
Like in drive sitting still or a cruise speed? You have to be very specific around here....
Old 07-15-2007, 12:57 PM
truck in just in the drive way. while i am in the truck holding the brake my brother in law is trying to set the air fuel mixture. all we got done break in the cam and set the intial timing 10 degrees. now we are trying to set the air fuel mixture.
Old 07-15-2007, 05:04 PM
It almost sounds as if you have a lumpy cam and no stall converter. You may need to elaborate some more on your particular setup. cam specs come to mind
Old 07-15-2007, 05:09 PM
yeah stock convertor and the cam specs are Brand: Lunati
Product Line: Lunati Voodoo Cam and Lifter Kits
Part Type: Camshaft and Lifter Kits
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,400-5,700
Intake Duration at 050 inch Lift: 219
Exhaust Duration at 050 inch Lift: 227
Duration at 050 inch Lift: 219 int./227 exh.
Advertised Intake Duration: 262
Advertised Exhaust Duration: 268
Advertised Duration: 262 int./268 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.468 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.489 in.
Valve Lift with Factory Rocker Arm Ratio: 0.468 int./0.489 exh. lift
Lobe Separation (degrees): 112
so do you think i need to get a stall convertor
Too much carb? KNanthrup Engine 5 09-03-2005 06:47 PM
25 Year-old Carb, rebuild or trash? Arcuden Engine 6 07-31-2005 08:42 PM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
What Came first Chicken or the Egg, or Carb Adj vs Timing riesman20 Engine 19 07-18-2004 10:26 PM
rochester 4 jet carb, rich Walker Engine 2 07-13-2003 09:42 AM
