carb swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2009, 11:22 AM
jrm123180's Avatar
A Learning Hobbist
carb swap
I'm thinking of putting my rebult 79 Chevy Q-Jet on my 69 Buck 430....anyone know of any issues I'm looking at? I know the linkage is a bit different but doesn't seem to be an issue. Are there any others that I'm not seeing?
Old 08-19-2009, 05:23 PM
fast68's Avatar
likes chevy trucks & boobies
not realy other than if the fuel line can be made to route and not run into anything
and if any of the vacuum pull-off valves dont hit anything especially the one on the rear, if so equipped.
it have electric or hot air vacuum choke?( big aluminum round choke housing)
or the spring and rod divorce style?(no choke housing)
choke might bt eh biggest issue, but not if its round choke housing type in which can be easily converted to OEM electric from an electric choke carb
if not already been done
dont forget pvc hose is the 3/8" diameter nipple under the center of the front of the cabr in the baseplate throttle valve assembly
and no need to worry about the other one in the airhorn on driver side at top in front
can leave it open and nothing plugged on it its just the bowl fumes vent
on later vehicles this connected to charcoal canister in which the 69 may or may not have one of
good luck
Old 08-19-2009, 08:06 PM
SS66chevelle's Avatar
HR VIOLATION
those q jets are notorious for having problems. They don't call them quadrajunks for nothing hopefully the person who "rebuilt" it has a lot of experience. If you are unsure, I would steer clear...
Old 08-19-2009, 09:54 PM
jrm123180's Avatar
A Learning Hobbist
older guy with a GREAT reputation rebuilt it and have been using it on my pick up for a few years with NO problems...the carb is in great shape.
Carb suggestions needed blownS10blazer Engine 12 09-29-2008 03:41 PM
TBI to carb swap eatonde Engine 20 09-09-2008 11:01 AM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 03:36 PM
Carb to TBI Swap? mrevil General Rodding Tech 2 03-26-2005 09:38 AM
Carb swap.. Good results! Trav Engine 6 09-11-2003 05:12 AM
