Carb swap tips - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-08-2013, 01:39 PM
spinn's Avatar
Booty Time, Across the USA
The afb , avs, holley and variant, q jets, webers, can all be dialed in to work on the street. It can be fun figuring out the differences in operation. The knowledge for functions of all the holes and pathways, is insightful as to where a issue could arise. Get a book that educates you on your specific carb. Get to know it.
Due to carburation working on a "square law" , you can place a 750 were a 600 was and get decent results from the common baseline.
The formula for carb selection should be a statistic for minimum size.
If you do not want to register, fill this field only and the name will be used as user name for your post.
Carb tuning tips? Madmax305 Engine 12 05-25-2011 10:40 AM
Tips for 8.5" GM 3.73 RingPinion swap spinn Transmission - Rearend 8 12-27-2010 08:14 PM
01 Crown vic getting an 04 cobra engine swap; tips? curtis73 Engine 10 10-27-2007 02:45 PM
Carb refinishing tips? DaSouthWon Engine 3 11-18-2006 06:15 PM
400 to a 350 engine swap any tips?? sparks55918 Hotrodding Basics 8 11-15-2003 04:27 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
