carb and timing specs - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2002, 10:18 PM
gm gm is offline
Thumbs up carb and timing specs
I have a 83 chevy k-10 with a 350 and a Q-jet carb.Im trying to figure out the timing specs,fast idle specs and idle specs.I tried to use the specs in a haynes which called for 1600 rpm at fast idle,700 at idle and 4 degrees BTDC and now its running like crap.
Old 11-11-2002, 09:05 AM
Post
set youre timing by ear,advace timing until engine backfiresand turn back until smooth idle or no backfires, rochester carbs are crappy on idleing strait.ive never had my roch idle strait with out it being real lean,buy a holley
Old 11-11-2002, 05:36 PM
dmorris1200's Avatar
doesn't play well with others
Post
I'm assuming you have a timing light since you know it's at 4BTDC. Start advancing the timing 2 or 3 degrees at a time and see how she runs each time you advance her. If she starts to ping under load back her off till pinging stops. Have you put the timing light on her while increasing rpm's to make sure your distributor is advancing properly?
BUILT FORD TOUGH
