carb tuning - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2004, 05:17 PM
Checy_Guy's Avatar
carb tuning
I have a mild 355 in my blazer with a 600 cfm q jet on a performer when i pull the plugs they are white this means its lean right so how do i tune my carb to get it not as lean?
Chevy-Rules
Old 09-25-2004, 07:07 PM
gpeak's Avatar
turn out the air/fuel mixture screws.
Old 09-26-2004, 11:13 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
Tune those until the car runs right. If your plugs are looking like that you can try a little less metering rod (or more primary jet, but metering rods generally get swapped first because they're easier to change). You may just be running too hot of a plug. What is your compression ratio?
K
