Carb tuning - LM2 csv file - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2013, 08:56 AM
Fang16's Avatar
Last journal entry: Project change
Up and running after going to twin Edelbrock 750's. All jets and springs are the stock settings. Hooked up the LM2 and went for a ride recording the trip. After a good warm up cruise I ran it through 1st gear. Looks pretty good AFR wise but sure there is a little more in there. Would like some input on what to do next. Here's the csv file from the short run in 1st. I have the log from the complete ride if needed and can upload it as the log file or an csv. The LM2 and associated software are really neat! Still learning it's possibles. Had to zip the file because csv's aren't allowed.
Oh, BTW, Going from 2 Holly 450's to Edlebrock 750's really woke this thing up!!
355 CI
11:1
Comp cams XR292R
Duration @ .050 254 intake 260 exhaust
Lift .582 .588
Edelbrock TR1YX tunnel ram 2 x 750 Edelbrocks
Ported double hump 2.02/1.60 3891462 64cc heads
700R4/3500 stall
3.90:1 ford 9"
Race weight 3257
80% Street/ 20% strip car
Old 04-08-2013, 02:49 PM
Fang16's Avatar
Originally Posted by F-BIRD'88 View Post
I don't have the softeware but was able to view the file as a text file.
As you can see the afr's are not very far off, with the default jetting.
Would be nice to get some more pulls in higher gears or accelerating thru more than 1 gear.
1st gear tends to wheel spin.
How is the drivability? throttle response? etc etc driving impression in different modes of driving...
For WOT testing,,, using 2nd gear makes for a longer, smoother test run ,,,, more AFR samples as the engine rpm accelerates slower.
having a manifold vacuum gauge visable while driving is very usefull for seeing the power step up point as you get into the throttle from part throttle cruise.
Driveably is great. Guess I'll make some 2nd gear runs on the interstate and even some cruises in 3rd. Will be going to the track later this month and will keep you posted. I'll keep an eye on the Vac gauge too.
LogWorks3 software is available from the innovate website and accel is a free download from MS.
carb tuning ghaddon Engine 3 03-15-2013 12:45 AM
Carb tuning help redride Engine 6 06-22-2009 11:00 PM
carb tuning Checy_Guy Hotrodding Basics 2 09-26-2004 11:13 PM
carb tuning 66ImpalaOn20s Engine 1 01-03-2004 07:29 PM
Carb tuning help, PLEASE! newchevyman Engine 4 10-02-2003 09:27 AM
