Carb Tuning QF750 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2013, 11:30 AM
Carb Tuning QF750
Two separate questions:
1. In order to get the best idle, the 4 mixture screws are each turned out 3/8 turn. Is this an indication that something's wrong? I always hear that they should normally be somewhere between 3/4 and 1 1/2 turns out. What can I do to get them within the proper range and what would that do to drivability and mixtures at light loads?
2. When would I tune WOT a/f mixture with secondary main jet changes, and when would I tune with secondary main air bleed changes?
Old 05-28-2013, 05:22 PM
LATECH's Avatar
What engine is this on? what heads...cam?
Fact is stranger than Fiction
Old 05-28-2013, 05:27 PM
327
11.5:1
aluminum 205cc angle plugs 62cc chambers .034 quench
250/246 106/110/114 .603/.608 solid roller .015/.018
dual plane intake Z28/LT1
headers into low restriction exhaust
supplemental cooling capacity enables 160 degree coolant temp, controlled with 160 degree tstat
93 octane (PON) pump high test
Crowerods
Old 05-28-2013, 05:31 PM
LATECH's Avatar
When you have it set to your "best" idle adjustment, if you create a vacuum leak, does the Idle speed increase and improve?
Old 05-28-2013, 05:36 PM
LATECH's Avatar
Go here:
Carb Class: Baseline Setting for your new car
Old 05-28-2013, 05:44 PM
No. It will stall.
No vacuum leak, carb brand new. All surfaces flat and sealed. Floats set @ 1/2 sight glass at hot idle. Idle speed 1100 RPM, 10 in-hg, best and most stable idle.Initial timing 20 plus 17 cent all in @ 2500. 12 degrees vac advance @ about 5 in-hg.
Old 05-28-2013, 05:52 PM
LATECH's Avatar
Put in larger Idle feed restrictions , it sounds lean at idle.
Be sure the throttle plates arent starting to cross the transfer slots , that will indicate the need for larger Idle feed restrictions.
10 inches of mercury ,isnt that pretty normal for a cam that large?
Whick Quickfuel do you have ? the SS?
Old 05-29-2013, 04:49 AM
Q- Series Carburetor 750 CFM DRAG
Transfer slots are AOK, about .020" exposed. I can idle it at 900 @ 8 in-hg if I want to, but rather have it fast at 1100 (cam oiling and throttle response both better).
Idle a/f ratio measured @ 14.5 with wideband.
Old 05-29-2013, 05:04 AM
[QUOTE
Idle a/f ratio measured @ 14.5 with wideband.[/QUOTE]
This is the problem IMO.
carb tuning ghaddon Engine 3 03-15-2013 12:45 AM
Carb tuning help redride Engine 6 06-22-2009 11:00 PM
carb tuning redneck_9018 Hotrodding Basics 2 12-12-2008 07:49 PM
Carb tuning help, PLEASE! newchevyman Engine 4 10-02-2003 09:27 AM
tuning carb satanic mechanic Engine 13 01-01-2003 01:27 PM
