Is this carb. usable? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2007, 03:37 PM
kringold's Avatar
ATA Welding Technology
Last wiki edit: How to rebuild an engine Last photo:
This is a Hitachi carb. by Holley. Is it usable, or should I attempt to fix/rebuild it? If I need to replace it, any suggestions on what kind, make or model? It's off a 1979 Ford Courier 2.3L which came stock with a manual choke, however this one has an electric choke and was hooked up. So I could go with either choke setup.
Name:	Carb top 1.jpg
ID:	26211   Click image for larger version
Name:	Carb top 2.jpg
Old 12-17-2007, 08:19 PM
just the vent tube is damaged? you can clean it up, rebuild it, and if thats the only damage, reuse the beast
Old 12-17-2007, 09:16 PM
kringold's Avatar
I'm not too sure I could find a rebuild kit for it. And I'm not too sure about the electric choke either. I've only had this running a couple of times myself and it seemed like it wasn't working.
Okay, say I want to replace it with a manual choke carb. Any suggestions?
Old 12-17-2007, 10:06 PM
SSedan64's Avatar
Rat Bait
Looks like you have some mean rats around. LOL
Old 12-18-2007, 05:55 AM
bondo's Avatar
Ayuh,.........
Best case,... Napa will have 1,......
Worst case,..... Ford will sell you a kit.......
Old 12-18-2007, 06:31 AM
31 five window
Last journal entry: grill and rear end
Be different, make an adapter and put 2,depending on cu.in., Harley side draft carbs. I took a fuel injected 3 cyl GEO metro,made a custom aluminum intake with one Harley carb and it ran great.Later that year I went to a World of Wheels show and ED"BIG DADDY" ROTH was there and he had done the same thing on his latest creation. I think it was 2001.
Old 12-18-2007, 04:39 PM
go to napa and or oreillys, and look through the book of rebuild kits, if they dont have it, anybody behind the counter with half a brain(good luck) can get you one.
Demon or Holley Carb for 306 Ford? Dino Boreanaz Engine 10 12-09-2006 06:04 PM
700 R4 tv cable hook up at carb murrsue Transmission - Rearend 4 10-18-2006 09:50 AM
Holley Carb. Question crusherdbuzz Engine 2 07-02-2006 03:25 PM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
Need some pointers on Holley carb crshrmn3 Engine 2 02-08-2003 11:22 PM
