Carb vacuum diagram - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-03-2007, 01:18 PM
Originally Posted by MIKE FROM SM
What makes you think the secondaries are opening late?
Well it's a 2 speed powerglide and I'm already in the upper rpm's when it starts to open. I would say around 4,000-5,000 rpm. Around 4-5K rpm I'm already doing close to 50 in first gear. ( I know I have really tall gears) But I was hoping with the other two barrels opening earlier. That that would help me off the line more. With a white spring ( the lightest) I would expect them to start to come on around say 2,500 rpm or so. I don't know maybe this is right where they are supposed to come on at.
  #17 (permalink)
Old 04-03-2007, 01:29 PM
Originally Posted by F-BIRD'88
Check the little cork donut shaped gasket that goes between the carb body and sec vac diaphram. If it is missing or leaks
between the vacuum housing and carb body, the vaccum signal that opens the secs at WOT, will be too late.
It will not build fast enough.
Usually when things are working right, No vac leaks, the lightest white spring is way way too light causing the secs to open too fast.
Generally a medium silver ( plain), yellow or purple spring is best for performance use.
That's what I thought. I thought the White one was way to light to be functional for most situation and car set up's
I checked cork gasket it's there and intact but I'm not saying it isn't leaking from there. I'll probably will replace it just because if it's not a problem now it soon will be. Thanks
  #18 (permalink)
Old 04-03-2007, 02:50 PM
Last journal entry: car is painted
With high gears and pg the secondaries should open very late. The engine should rev up smoothly. If it doesn't, the secondaries are opening too soon. Keep putting in a stiffer spring until it does rev up smooth. Or put some low gears in that thing.
  #19 (permalink)
Old 04-03-2007, 02:58 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
jet extensions with high gears and PG...on a carb that will barely open the secondaries, LOL! don't make him spend any more than he has to, k??
2-late, can you get me a good pic of the primary/secondary linkage off the driver side of the carb?
  #20 (permalink)
Old 04-03-2007, 04:26 PM
Yeah I'll do my best may take a day or two but I will try to take lots of pictures all the way around so everyone can see what I'm talking about.
It feels smooth the whole time I can just hear and feel the extra "boost" when the secondaries open up.
Thanks Guys talk to ya tomorrow Brian
  #21 (permalink)
Old 07-28-2013, 08:38 PM
Originally Posted by 2_Late_I_Won View Post
My secondary isn't opening on my old school Holley 625-600 cfm carb. I don't know jack about carbs. but I know the diaphragm is good. I took it off and put a vacuum test to it and it stayed down. So I know that is good. I started it up and didn't feel any vacuum where the diaphragm goes and didn't feel any vacuum. I put the air hose to it to blow out any thing that might be blocking it but nothing came out and it blew freely. Like I said I don't know that much about Carbs so any help would be greatly appreciated.
I'm having the same problem on my 600 cfm holley 4175. I'd like some ideas too.
Robin
  #22 (permalink)
Old 07-28-2013, 11:55 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Just take the information in this thread and run with it...
Semper Fi
Vacuum advance hooked up directly to manifold....is this bad????? Steve-0321 Engine 69 03-10-2014 06:10 PM
vacuum advance help batman09 Engine 14 09-09-2004 10:42 PM
Vacuum advance from my carb to Dist.Do I need it? batman09 Engine 9 09-07-2004 10:22 PM
Vacuum hose routing diagram? 87442lover Engine 2 01-24-2004 09:08 AM
Mustang V-6 motorcraft 2150 carb. vacuum routing? 87442lover Engine 1 04-24-2003 11:51 AM
