Carb vacuum diagram - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2007, 01:10 PM
Carb vacuum diagram
My secondary isn't opening on my old school Holley 625-600 cfm carb. I don't know jack about carbs. but I know the diaphragm is good. I took it off and put a vacuum test to it and it stayed down. So I know that is good. I started it up and didn't feel any vacuum where the diaphragm goes and didn't feel any vacuum. I put the air hose to it to blow out any thing that might be blocking it but nothing came out and it blew freely. Like I said I don't know that much about Carbs so any help would be greatly appreciated.
Old 03-28-2007, 03:05 PM
Last journal entry: car is painted
It won't pull a vaccum unless it is under a load. It won't happen when in park.
Old 03-28-2007, 03:52 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
I'd be looking at the spring in the diaphram
Old 03-28-2007, 04:12 PM
MI2600's Avatar
Member# 3287
Take the vacuum unit off the carb. Push the rod gently up and plug the port with your finger. If the rod stays up, the unit is functioning.
Old 03-29-2007, 06:58 AM
re: Carb vacuum diagram
Try this site for answers. You may have to search the site for your problem. If you can't find it send them an e-mail. Holly is good about answering problems. Be sure to know your model#.
http://www.holley.com/TechService/
Old 03-29-2007, 07:08 AM
Yeah I took the vacuum unit off and put a vacuum on it and the rod pulled down. I revved it up and could feel any vacuum on the port on the carb.
I went looking to try and find out the model # but could find anything that stuck out to me as a model #. I drove it up to O'Reilly's and had a guy that said he knew about carbs and he had a hard time finding it too. He said it was from about the 1970's or so. ( he also said he knew about carbs. but he didn't tell me how much he knew about carbs. LOL)
Thanks for the reply's
Old 03-29-2007, 07:59 AM
NXS's Avatar
NXS NXS is offline
it is a ported vacuum source that only has vacuum when the engine is pulling more air than the primaries can provide. it is weak and often the stock springs in the vacuum pod won't fully open until 7000+ rpm. They are color coded so if you can see what spring you have and the rpm it will take to open it.
Old 03-29-2007, 09:08 AM
This is where to find the list #. From the Holly site.
QUESTION How do I find the "list" number on my carburetor?
ANSWER The list number for most performance and factory 2 and 4 barrel carburetors will be found stamped into the upper right hand corner of the airhorn or sometimes called the choke tower. On the 4150 HP models that do not have a choke tower the list number will be stamped into the mainbody behind the throttle linkage. This number is used to identify the carburetor and also used when needing service parts or renew kits.
Old 03-29-2007, 09:36 AM
Thanks 66BOWTIE when I get home I'll have to ck it out.
Old 04-02-2007, 09:27 AM
It said R75 but that doesn't sound like model number to me. Oh well!!! Anyway I took apart the secondary and noticed there was a Black spring in there it seemed kind of stiff. What color should it be and is the black one stock or do you think it's been changed out before?
Thanks again Brian
Old 04-02-2007, 10:37 AM
NXS's Avatar
NXS NXS is offline
White, yellow...to black....black being the stiffest and latest opening
Old 04-02-2007, 10:42 AM
AHWWW HAAAA I think I found my culprit Sweet thanks I'll have to get another spring and see if that helps.
Old 04-03-2007, 07:16 AM
Well I went home last night and bought a vacuum secondary spring kit. I put the white one in ( the lightest/less tension )and my secondaries open up yeah the only problem is it opens up in to high rpm. Right about the time I want to let off the secondaries open up so I don't get to enjoy the extra power. Is there a way to increase vacuum so it will open up sooner or a way to adjust when it opens up? I know usually you would adjust when the secondaries open by getting a little bit stiffer spring but since I have the weakest on in there now I don't know what to do. Do you think I can run it with out a spring at all or do I have to have one to push the diaphragm back down?
Thanks again for all the help now I just need to fine tune this thing
Old 04-03-2007, 07:54 AM
NXS's Avatar
NXS NXS is offline
you can pull the spring out and either push it inside out to soften it so the secondaries are open sooner and stay open
or
cut the bottom off, this will give an initial hit at lower rpms then slowly open in the upper rpms
The Following User Says Thank You to NXS For This Useful Post:
PatM (07-28-2013)
Old 04-03-2007, 09:37 AM
What makes you think the secondaries are opening late?
Vacuum advance hooked up directly to manifold....is this bad????? Steve-0321 Engine 69 03-10-2014 05:10 PM
vacuum advance help batman09 Engine 14 09-09-2004 09:42 PM
Vacuum advance from my carb to Dist.Do I need it? batman09 Engine 9 09-07-2004 09:22 PM
Vacuum hose routing diagram? 87442lover Engine 2 01-24-2004 08:08 AM
Mustang V-6 motorcraft 2150 carb. vacuum routing? 87442lover Engine 1 04-24-2003 10:51 AM
