Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Carb vacuum diagram
  #18 (permalink)
Old 04-03-2007, 12:29 PM
2_Late_I_Won 2_Late_I_Won is offline
Originally Posted by F-BIRD'88
Check the little cork donut shaped gasket that goes between the carb body and sec vac diaphram. If it is missing or leaks
between the vacuum housing and carb body, the vaccum signal that opens the secs at WOT, will be too late.
It will not build fast enough.
Usually when things are working right, No vac leaks, the lightest white spring is way way too light causing the secs to open too fast.
Generally a medium silver ( plain), yellow or purple spring is best for performance use.
That's what I thought. I thought the White one was way to light to be functional for most situation and car set up's
I checked cork gasket it's there and intact but I'm not saying it isn't leaking from there. I'll probably will replace it just because if it's not a problem now it soon will be. Thanks
