Carb Vacuum Trouble - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2012, 09:01 AM
Carb Vacuum Trouble
With the full time vacuum line disconnected and plugged from the distributor and idling at 700 rpms when the line is hooked back up nothing changes. I checked for leaks around the carb and found none. A vacuum gauge was hooked to the intake manifold and just bounces around from 0 to 25. Is this normal or must the reading be steady? Thanks GOWSER.
Old 11-03-2012, 08:43 PM
Short answer - the vacuum reading should be steady at idle. If it bounces from 0-25 there is something way off.
Bruce
vacuum advance trouble 305rocker Engine 9 11-27-2011 07:14 AM
Trouble with automatic transmission ? vacuum 41FordBusinessCoupe Transmission - Rearend 6 04-12-2010 08:51 AM
Vacuum Trouble - Chevy 350 Fragzem Engine 2 11-08-2003 10:37 PM
Vacuum trouble 5.0 Fury Engine 1 08-08-2002 05:37 PM
vacuum trouble chale24088 Engine 0 07-14-2002 09:17 AM
