carb warning about auto overdrives? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2006, 08:47 PM
i have a new 383 engine and had problems with my demon carb. the compant that built my engine sent me a holley 750 double pumper. i was getting ready to install and i read in the instructions that it says this carb can not be used with automatic over drive trans. this was a warning. now below this warning it says not to use on fords because it has no kick down lever. now in another picturs it shows were to hook an gm automatic trans.
i have a new rebuilt 700r4.
so my question is will it hurt it, or is the warning only for the fords?
need quick reply because i was planning in installing tonight.
Old 04-06-2006, 09:12 PM
well sorry for the post lol i found out why when i dont a search on the internet. it came up with that exact question from holleys web site. man do i fell dumb. anyway the warning was basicly to make sure you use the correct kick down bracket and cable stud.
Old 04-06-2006, 09:17 PM
powerrodsmike's Avatar
Wiki Edits: 161
If you are using a 700 r4 it is called a TV cable. It needs to be adjusted correctly or your trans will mess up. Look at this a little
http://www.700r4.com/faq/whattv.shtml
later, mikey
BE different....ACT normal.
Old 04-06-2006, 10:46 PM
thanks i do have that one and i just installed the carb and used my old bracket. i will adjust tomorrow. the warning was mainly to make sure a bracket or the holley bracket was used. i will get the correct holley part number one tomorrow. thanks next time i will do more research on the net.
WARNING Mr Gasket Fuel Filter Problems SilverFox2 Engine 11 09-08-2008 04:36 PM
Too much carb? KNanthrup Engine 5 09-03-2005 06:47 PM
Manual Holley carb on auto car sleepr Hotrodding Basics 1 08-11-2005 09:01 PM
What Came first Chicken or the Egg, or Carb Adj vs Timing riesman20 Engine 19 07-18-2004 10:26 PM
rochester 4 jet carb, rich Walker Engine 2 07-13-2003 09:42 AM
