carb whistling
i have a barry grant road demon 625 carb and at high rpm it will start to whistle like it is spooling up like a turbo. sounds like a vacuum leak does anyone know what it might be and if so what i can do to fix it. and i know its not a vaccum leak from anywhere else because i change the intake gasket and carb base gasket and i also checked all vacuum fittings and everything is fine.
Thanks- Juan |
Are yoy running an open element air filter?
Shane |
Dirty air bleeds?
have you tired cleaning the carb with some carb cleaner and hold it at 2500 rpm?
I do have an open air cleaner. but i've always had it and it just started doing it. and no i haven't tried to clean it with carb cleaner
Carb Whistling Solution
After searching the forums and the internet, calling Holley and still no luck fixing a whistling sound coming from the bowls (specifically when a load was placed on), I finally fixed the issue. The carb spacer I was using was an open plenum aluminum. I switched to a 4 hole spacer and away went the whistle. Also added a noticeable low end boost as well.
| 700 R4 tv cable hook up at carb | murrsue | Transmission - Rearend | 4 | 10-18-2006 09:50 AM |
| Holley carb problem | crusherdbuzz | Engine | 3 | 07-09-2006 03:12 PM |
| Holley Carb. Question | crusherdbuzz | Engine | 2 | 07-02-2006 03:25 PM |
| Holley carb has me at wit's end | cool rockin daddy | Engine | 23 | 06-02-2005 02:38 PM |
| Need some pointers on Holley carb | crshrmn3 | Engine | 2 | 02-08-2003 11:22 PM |
