Carbed ls motor hard to start hot or cold
I have a carbed 6.0 ls motor with a 650 edelbrock avs. I have a hard time starting when cold and when hot. The weird thing is the first couple times i fired it up it started right away. I am using the msd 6010 ignition box and I've tried all the pills all with the same result. it sputters and pops and has even shot a little gas back out of the carb. Once it's running it drives great and idles fine. If i shut it off even for a second it's hard to start again 90% of the time (sometimes it starts right back up). Thanks for any suggestions.http://s370.photobucket.com/albums/o...wap%20caprice/
how can i tell if it's leaking down? I have a holley blue pump and i have noticed that after i shut off the car the fuel pressure gauge goes back to zero. not sure if that's normal. when i have the key on fuel pressure immediately goes to 6 psi
Other than the carb leaking and emptying the bowls, there's a possibility it could be flooding the intake/cylinders as well. After it sits a while see if you have a shot from the accelerator pump nozzles when you open the throttle, with the key off.
It's normal for fuel pressure to drop when the pump isn't pushing fuel to the regulator or carb. If it's hard to start within seconds of shutting off, and you're not pumping it on restart, it sounds like what DV said, flooding.
Midnight Sun Street Rod Association |
Carb float levels
Check and make sure the Carb float levels are correct high fuel levels will drain and wash the oil off the cylinder walls and make starting all but impossible until it dries up
I checked if the carb was leaking down and it was fine so i put my thermal gun on all the lines and carb after i was up to temp and didnt see anything crazy. later that day i got my cable to connect my laptop to the msd box so i plugged it in and low and behold it said cam snsor fail so i went to remove my cam sensor and noticed the plug was loose so i secured it and all is well. starts with a turn of the key and no pedal now. I do have an off idle bog at wot and another bog from mid throttle to wot so once i work that out i'll post up some vids for everyone to enjoy. thanks for the suggestion guys i guess i had a brain fart and didn't check the obvious first. i still don't know how it was running at all without a cam sensor signal?
Check the input voltage at the MSD box. It could be marginal until the car starts and the voltage rises due to the alternator kicking in. Low voltage could be a bad connection, bad or undersized wiring, bad ground etc. The power to the MSD box is supposed to come directly from the battery.
Artificial Intelligence is no match for Natural Stupidity Chet |
I see you have your MSD box mounted on the intake. It should be mounted away from the engine. It is possible that the ignition box is getting heat soaked when you shut the engine down, thus cause hard starting. Just a thought. By the way, How does that car go? Is that a stock 6.0 liter? Whats it out of???
| 87 gm tbi hard to start when cold | chevyAL | Engine | 4 | 01-14-2010 04:14 PM |
| Easy cold start, hard hot start | dedub | Engine | 34 | 08-13-2008 05:21 PM |
| 400 hard to start when cold | zoc65 | Engine | 6 | 06-24-2008 07:56 AM |
| hard cold start | akm | Engine | 19 | 05-16-2004 10:46 PM |
| turbo on a carbed motor? destroke? | fireturkey | Engine | 18 | 12-27-2002 07:00 AM |
