carbed lt1 lets try tbi plate and make it a fi lol
Hey all long time no see.. I just put a lt1 b-body in my camaro (1985) took the fi off went cab with intake NOW I wanna try a tbi adapter plate for carb engine and make it tbi for shi***s and giggles I know most will say why did you take the lt1 fi off in the first place but hell can't a man play
I think with the bigger runners on the carb intake and tbi she should still haul *** and be decent on gas... Let m e know what you all think I think it would be fun to try just to say I did it.. I mean really ? Who does a fi to carb to fi mod LOL Any people who wanna pipe in POSITIVE advice please do thanx for looking let the fun begin !
thanx for tips etc
I am planning to run the gm performance lt1 carb intake I know I can do a tpi setup but my car came carb in 85/6 I want to use the adapter plate and use a tbi harness and throttle body ( as under the breather most would never know it was tbi tee hee) I think it would run decent and be rednek fuel injected. I have the intake off the lt1 etc but I have been down that road wanna try something new besides tbi is so easy to hook up and with minor mods it can haul *** I think I am only stumped on if the ecm will handle the lt1 cam that is the only problem I can see but seeing this was a b0body lt1 I think it was a slightly smaller cam than the f-body ALSO for all of you about to say the aluminum f-body lt1 was better you might wanna do some research the b-body made more torque and was only 15hp lower.hmmmmmmmmmm now that i have the lt1 carb intake it is up to 35% more torque and equal in hp JUST a tid bit PLUS I can run pump gas. Anyone who knows a place or thinks the ecm will be fine let me know.. This is going to be one of the cheapest builds I have done since you all helpeed me here on my chev 4x4 tbi mod.. Thanx again
if you use only one 2 barrel TBI unit, use one from a 454, the bores are a little bigger.
if you have the stock LT1 cam, it shouldn't be a problem. with computer tuning, there are people running much bigger cams with fuel injection without a problem. for best performance, you'll need an ECM that you can tune. you have a few choices here. 1, get one of the aftermarket systems. 2, get a mega squirt. 3, use a factory TBI ECM and get the software to edit the bin and the hardware to burn chips. 4, get a EBL. the aftermarket systems are viable, but if something happens to the ECM, you'll be down until you can get another one. for the price, i feel the aftermarket systems are not a good deal. with a mega squirt, you build it yourself so you should be able to trouble shoot and repair it. im not sure about the MS 2, but the MS 1 wouldn't control ignition timing. a with factory system, data logging is on the slow side unless you use an ECM from one of the later model pickups like a 94 or 95. using a 94 or 95 TBI ECM would let you run an E-transmission like a 4L60E or a 4L80E. the EBL, or Embedded Lockers is based on a factory GM ECM. i've talked on-line to a number of people who have the EBL and most are quite happy with it. http://www.dynamicefi.com/ with any computer tuning, there is a learning curve involved. the info for learning computer tuning is available for free on the internet on a number of web sites. you'll probably need an adjustable fuel pressure regulator. even with computer tuning, the fuel pressure still needs to be within a certain range. |
| Roll Bar Install Advice | Mustangsaly | General Rodding Tech | 12 | 12-02-2007 08:33 AM |
| Th350 going to break, how to make spacer plate holes smaller? | Jason | Transmission - Rearend | 7 | 06-30-2003 10:29 PM |
