carbonator on an eaton m-60 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2012, 08:16 AM
eaton m60 + geo metro
hi all
i am going bravely where i have never gone before.
the plenum/m60 mount is partially complete at this writing, the goal is make "it" run like "its" @ sea level. ok, ok, a small percentage more......so, with that said, here is what i am working with
"it" is a carbonated geo metro 3 cyl, 5 spd, bone stock, daily driver, to be fed with an eaton m60 short snout, off a buick 3.8. altitude here, 5000'
will all you with forced induction experience be so kind as to guide me thru this?
pully ratio? ig timing? dump valve control?
totally grateful for your input
mark
Old 02-09-2012, 08:28 AM
Last journal entry: update
Seems you've jumped in to the deep end ( of enthusiasm ) head-first, without seeing the rocks ( researching ). Maybe you came across this blower, and were already sick of the Geo being so slow?
Several problems here. First is custom-mounting it. Second is connecting its output to your intake manifold, third is fueling, and fourth is that it won't all fit under the hood, even with the largest street-legal scoop / bulge. Possible fifth: adequate cooling. Probable sixth, probable clutch failure.
This is not a quick, cheap, easy proposal. You'd do better trying to play with a small turbo.
If you want to do a mutant Geo, fine, get something else to drive, then start an entire engine swap in the Geo.
If you just want more performance for cheap, then either sell the blower to buy a nitrous kit, or sell the blower and the car, then buy something that can move quicker.
Old 02-09-2012, 09:48 AM
well bless your little heart, you did try to warn me
indeed my friend, indeed i have jumped, and thank you for your optimistic and enthusiastic blessing on my post/project.
i am having a bit of difficulty deciphering answers in your positively encouraging verbage to the questions asked in my post, but i will re-read it.
oh my, i wish you or someone would have told me a blower wouldn't mount or fit under the hood before i did it. that sure would have saved a perfectly good m60 for someone else to use....
mark
ps: wasn't it walt disney that got flamed for his ideas before he did them?
Old 02-29-2012, 10:02 AM
hey ya'll happy tuesday
ok now, on with the fun.
is there anyone on this site that is knowledgeable in forced induction?
a short while ago i posted "eaton m60 + geo metro", the responses here have been, less?, well, different than i had hoped for.
perhaps some or one of ya'll can direct me toward a forced induction guru / forum / site?
i wish each and every one of you the very best on any and all projects you are involved in or even contemplating.
remember to be gratefull for the experiences you learn from your projects.
mark
Old 02-29-2012, 11:33 AM
for a metro specific forum try teamswift.net there is a lot of knowledgeable forced induction guys there.
My recommendation is to try to find a smaller blower, a m60 is too big for a 1l 3cyl. I would look for a sc14 off a toyota pariva.
Metros are good cars I had 3 of them back in the late 90s early 2000s and besides the tendency to burn exhaust valves I never had a issue with mine and I ran them pretty hard.
Old 02-29-2012, 11:35 AM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
You're going to put one of these on your supercharger?
http://www.google.com/products/catal...7976216847660#
Old 02-29-2012, 11:40 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I merged your old thread with the newer one. In the future, rather than double post, bump your old thread.
Semper Fi
Old 02-29-2012, 01:00 PM
Rhansen's Avatar
Footbraker
IIRC that should be an eaton m90 (afaik all the s/c 3.8L had m90s) and they typically have coated rotors. IIRC running fuel thru the blower will strip the coating and ruin the s/c.
Old 02-29-2012, 02:31 PM
thanx and oops
68novaSS, oops! thanx for the lesson, im kinda new at this.
kewl! teamswift.net, i will be havin a look there. thanx bro.
nice find there blazin, hmmm i got this batch of diy honey mead....... noooo not on the sc, a bit of lugnut artistic liscense, ie:dizzy=dis-trib-u-tater, ford suv=exploder, chevy aveo=avacado, omni=omlett, what other ones come to yall's minds?
sc14 tojo pariva thanx i shall look in2 that. well this is all new territory to me and that thing about coated rotors, yes they are slick grayblack in color, very similar feeling to your teflon fry pan. they dont like gas??? well we got that in common, the gas for the last few years is some total crap! who knows perhaps i should carbonate the gas........living here at 5000' and most drives are up hill from here, like 1.5 hours to the continental divide on us50, id like to use 4th and 5th gear for something other than down hill. ya know, push enough air into the little thang to make it think it's runnin at sealevel.
spose ya could use nox instead of co2 for the bubbles ????? why not? in a pressurized system, between the pump and the injectors....snap out of it!! back to the post!! i sez to myself
um, pardon me ignorance here, help me with "IIRC" & "afaik"
tis a blast chattin with ya'll
mark
Old 02-29-2012, 03:03 PM
Banned
If you just want to boost it then go with a t25 turbocharger. They are dirt cheap (people upgrade to bigger units) and MUCH easier to install than a supercharger.
Then you can look at intercooling it and doing a blowthrough setup with a carb (though I would pefer EFI). you'll be way ahead in power and mileage compared to your M60 idea and it is MUCH easier to build.
Old 02-29-2012, 04:31 PM
Last journal entry: My Last Hot Rod
Ram Air
ring a bell?
Old 02-29-2012, 08:00 PM
cal1320's Avatar
I was playing around with putting an Eaton on a 2.5L Jeep I had. I have an Eaton off a 3.8 L Bonneville. I think its an M62. They move 1 liter of air per revolution. It also has a bypass valve built in to dump the boost when the throttle is closed. The Previa blower is smaller in size and capacity (maybe better suited to the Geo). But it has an electric clutch (like an ac compressor) that turns it off and on. Mercedes Kompressor uses a clutched eaton also.
