I would personally not go above 600. The 2 hp you gain at redline tends to be more than offset by greater difficulty tuning and potential loss of low end torque due to the slower velocity.
If you run a well tuned professionally built carb you can get away with much more carb than just going with a box stock unit with a jet change. IT all depends on what you want and what you want to spend.
For using a box stock carb max cfm should be about 2Xdisplacement (in CI), for most street engines. Another rule of thumb is max hpX2=cfm. |
| supercharger.... | 73monte | Engine | 16 | 07-24-2010 10:27 AM |
| Port CFM vs. Valve Size vs. Port Velocity...Data WANTED! | Elevinpointsixtoone | Engine | 45 | 04-17-2006 12:37 PM |
| Chevy question | Ratoflic | Hotrodding Basics | 1 | 11-02-2005 09:55 PM |
| Ignotion Set-ups | Native Gearhead | Engine | 8 | 11-29-2003 01:20 PM |
| Hi All I just Joined, Questions Re:454 rebuild | Gay-Shark | Engine | 8 | 11-29-2003 10:25 AM |
