carbourators
what could cause a quadra jet 4 barrel to leak gas out over night
Otherwise it could be heat soak- the hot engine temp could be percolating/evaporating the fuel out of the float bowl. |
Also, if there is no filter in the inlet, it can siphon back out.....
Ontario Rodders |
NAPA is a nation wide auto parts store. remove and measure the diameter of your plugs and tell them you need well plugs for a Q-Jet carb with this dimension. If they don't have them a good carb shop will. The easiest way to tell if you have leaking well plugs is to get your engine hot. Shut it off, wait 20 mins, remove your carb lifting it straight up and look at the bottom of it. If you see gas dripping from the throttle plate you got bad well plugs.
Well my NAPA guy couldn't find them either. But he's only twelve. A quick google and here is the results.
http://quadrajetparts.com/advanced_s...ef74c0&x=0&y=0 As I said before, there is more than one size hence more than one part # I never said the o-ring was made of rubber. They have been using o-rings in carburators for years. Ever re-build a Holley? |
Nah, never. Appreciate the link.
