Carbs - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 06-08-2007, 06:26 PM
Carbs
Am building a 57 Chevrolet Hot Rod with "period" engine components. Will be installing a dual 4 Barrel manifold with Carter WCFB carbs. Can anyone offer info on the year/s this carb option was available?
Geezer1
Old 06-08-2007, 09:50 PM
MrPhotographer06's Avatar
Army Strong
Last wiki edit: How to remove a VW Type I body
Last journal entry: well once again
Howdy geezer1, Welcome to Hotrodders Check out the Knowledge Base for inspiration or info. Also try and preform a search before posting because someone else may have asked a question close to yours and it'll save you some time also. Try and give as much info as possible when posting to help the posters answer your question to their utmost potential Thanks and Welcome
Try asking your question in the engine section. This section is only for the introductions . Thanks
-Scott
Progressive Linkage On Blower Carbs Setup? 5-7heaven Engine 6 10-07-2007 11:30 AM
Offy 6x2 with Ford 8BA carbs? rlackey Engine 8 04-26-2005 07:38 AM
A roots style blower that runs on blow thru carbs? Jared Engine 6 01-28-2005 05:50 PM
Edelbrock -JET-DeMon-Holley performance carbs tm454 Hotrodders' Lounge 0 03-30-2003 07:07 AM
one 4 barrel carb or multi carbs........... onebadmerc Hotrodders' Lounge 13 02-07-2003 08:56 AM
