carbueretor choices? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2012, 09:43 PM
ok i just built my 390 fe federal mogul pistons std. bore cobra jet valves ported heads edelbrock rpm manifold and a lunati cam advertised dur. is 300/300 and lift is .515,.515 any suggestions on a carb size would be GREAT THANKS LOUIS!
Old 03-22-2012, 02:07 AM
DoubleVision's Avatar
A 750 CFM will suit it fine.
Old 03-22-2012, 09:11 AM
ok
ok thanks a 750 vac. or mech.?
Old 03-22-2012, 10:11 AM
Last journal entry: had some warm weather but its gone,hate winter!...and header woes!
Location: midcoast maine in the small town of waldoboro
Even tho both decent carbs Im not a huge fan of the orig edlebrock perf or holley 4160(never tried a holley street avenger) IMO the eddy thunder series AVS is prob the best of both worlds being able to adjust the secondary rate unlike the orig performer (except no 750cfm that i know of AVS's go from 650cfm then jump to 800cfm) 650cfm should b fine for street it will support 350+ hp,i just always hated a vac pod moving the secondary blades even tho they are adjustable, i feel the eddy AVS give will u that mechnical feel like a Qjet does imo more than a holley vac...but even tho most wouldnt agree u could run a mechanical secondary but it would require tuning and prob smaller cfm to work good in a heavyer car and as u know mpg gets worse with a double pumper.and at $4+ a gal. 10mpg gets old..sorry about the long winded response.
Old 03-22-2012, 11:55 AM
AED 750 "HO". AED Holleys have proven to be excellent "out of the box". They do more 'prep" than any other carb place I know of.
Advanced Engine Design, Richmond, VA. (804) 271-6076
Jim
Old 03-22-2012, 04:42 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Jim
X2
Cole
Choices, Choices and choices ? 396flyby Engine 0 05-31-2009 07:41 AM
help...on choices douhavit Engine 6 02-15-2005 09:42 PM
Choices, Choices..... I need opinions Centerline Hotrodders' Lounge 6 04-02-2004 10:16 AM
Hemi update and choices, choices! HemmiGremmie Hotrodders' Lounge 3 09-07-2002 08:54 PM
