carburator size
Im sure this question has been asked several times over regarding the size of the carb to put on. Thanks to everyone who found the right answers regarding my 350 which turned out to be a 305. So my question is would a edelbrock 600 cfm be to much for the 305. I have a carter c500 carb on it now.
I ran an Edelbrock 600cfm Carb on my 1984 305 Pickup for the longest time and it ran great. Go ahead.
There is a simple formula to use for a guideline only. Displacement (in cu in) X max RPM X volumetric efficiency (use 92or so if you don't know) all divided by 1728 gives you cfm for a carb. Round up to what's available. Not perfect, but a good starting point for normally aspirated engines.
PatM |
Yes go ahead and try a 600, it'll run great.
thanks everyone for your comments ill defenitley try the 600. maybe that will help with my gas mileage. im getting about 8 miles to the gallon so hopefully the old carb may be the problem
It depends on the carb adjustments, and the size of the jets and rods.
a 500 cfm it's an old Carter then? |
| Carburator | mytruck | Hotrodding Basics | 3 | 02-27-2012 07:15 PM |
| carburator size very mild vortec chevy | kennyhammond | Hotrodding Basics | 3 | 12-13-2011 08:40 AM |
| carburator? | 49fordp/u | Engine | 7 | 01-09-2008 10:23 AM |
| Carburator | buff | Engine | 15 | 03-20-2006 11:19 AM |
| too much carburator? | 68bird | Engine | 21 | 07-08-2004 07:36 PM |
