carburator size very mild vortec chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2011, 09:49 PM
Needing to know what size carburator I should use for my 350 vortec
...nothing much different from stock except slightly bigger cam....
Old 12-12-2011, 10:57 PM
psbaker75's Avatar
600 cfm is fine, you can run a 750 but its overkill for a stock it nearly stock motor. My vortec headed, moderately built 350 (approx 375 HP) does fine with a 600 edelbrock
Old 12-12-2011, 11:41 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Either a Q-jet or a 600-650 cfm vacuum or air valve secondary. You don't need a double pumper or any more cfm. Keeping the carb in this range will give a crisp throttle response and decent economy.
Old 12-13-2011, 09:40 AM
O thanks I have a couple quadrajets laying around my try to rebuild one..( never Don it before) or pick a 600. Up from craigslist ...thanks guys
chevy 350 mild motor jeremy1992 Engine 15 01-03-2012 02:45 PM
Mild build chevy 350 guts question dadicted Engine 16 10-19-2009 07:26 PM
Chevy Van building mild motor racprops Introduce Yourself 2 09-22-2009 10:16 PM
What Size Air Cleaner for Mild 350 JohnTN Engine 1 12-11-2006 11:05 PM
Minimum carb size for a mild 455 Sparky06 Engine 2 07-13-2005 10:45 AM
