carbureater cleaner
i am looking for a basic recipe for parts cleaner. $20.00 a gallon is very expensive when smaller amounts are needed.
How about the stuff in spray cans from parts store. If you went to the store and bought all the solvents in carb. cleaner, there would be more than $20 invested.
as far as using carburator clener as a solvent is concerned it works great. I have used it on grease,oil,paint and just about anything you can think of and it works great
Use gloves - it took the top layer of skin off my hands. |
If you are looking for a soak type cleaner then anti-freeze works quite well, someone put me onto that here a couple of years ago and I have been using it since.
Found it, carb cleaner alternatives? |
kerosene is all use
cleans anything even chassis grease makes chassies spotless with just a small brush also will clean road tar off car paint without hurting at least older ones anyways |
Kerosene does indeed work quite well to remove oil and grease however it does next to nothing to remove carburetor gunk and accumulated crud on internal engine parts. The carb "dip" that is available at auto parts stores works ok as far as removing the internal built varnish in carbs but it sure don't do a lot for the external appearance, I have yet to use the anti freeze for that however.
One thing I have no use for is the "Gunk" type engine de-greasers in the spray cans from auto parts or Wal-Mart. Following the directions on the can you start with a warm dry greasy engine, spray the stuff on, wait a few minutes then just hose it off- PRESTO, you now have a cold,wet greasy engine!
I agree with you on Gunk. Actually, the stuff works well to remove grease, etc from engines, but when you spray it on and it desolves, make sure you have a pan or something underneath because the oil and everything drips on the ground and is very messy. The other problem with Gunk is the smell. It's horrible. When the engine heats up, you smell Gunk degreaser for months. I threw away several can of the crap. |
Wiki'd this: Parts cleaner.
HomemadeTools.net -- Thousands of Homemade Tools |
| Recent Garage - Tools posts with photos |
| Runs Like Crap With Air Cleaner On - why? | leejoy | Engine | 30 | 11-16-2010 06:08 PM |
| what else in in wax and grease remover besides mineral spirits? | Dubz | Body - Exterior | 47 | 06-19-2010 12:09 PM |
| Air cleaner advice. | ScreamingEagle | General Rodding Tech | 2 | 09-18-2006 10:59 AM |
| wax and grease remover | adrock430 | Body - Exterior | 14 | 07-30-2006 12:18 PM |
| Toilet Bowl Cleaner! | scrot | Body - Exterior | 35 | 06-08-2006 07:07 AM |
