Carbureted Vortec HEI Timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2012, 02:23 AM
GUITAR1989's Avatar
Guitars & Cars >8D
Hey guys I got my Vortec 350 in my 74 c10. Im just a bit confused on vortec timeing and vacuum advance to be more specific. My truck has a stock L31-R crate long block with an edelbrock 600cfm, Weiand Stealth dual plane, Headers, Dual exhaust, 3.73.
10*initial+20*mechanical is that a good safe starting point for my engines timing? Should it be in by 3000 or is it different since the engines in a heavy truck? I have an adjustable vac can on its way to the local parts store. Vac advance is throwing me off a bit. Im going to run manifold vac. What should my vac advance be limited to? and what should it be reading at idle and part throttle? My engine pulls about 20hg at idle if that matters.
Thanks for reading guys
Old 08-28-2012, 06:20 AM
Carbureted Vortec Hei Timing
Here is an article on setting engine timing. it will explain everything in detail. http://www.crankshaftcoalition.com/w...EI_distributor
Old 08-28-2012, 08:06 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Vortec heads can use 32-34 degrees total advance (not counting vacuum advance). So you will be safe at 10 degrees initial/20 degrees mechanical. In fact you might find the engine liking slightly more initial, this will depend on the vehicle and use, etc.
The 'all in by' rpm depends on the load the engine is under. You want the total timing all in as soon as the engine will allow it, w/o any detonation. And in most cases this can be done by 3000 rpm or before. But with a truck being worked hard you might not be able to get all the timing in by 3000 rpm w/o pinging- it depends on weight, load, gearing, fuel quality, cam specs, compression ratio, etc.
I would set it up conservatively at first, then work towards bringing in the mechanical timing sooner by using a lighter spring or springs (the springs can be mixed and matched- they do not have to match on both sides).
The vacuum advance adds about 10-12 degrees. The page cdminter59 linked to has the details.
Old 08-28-2012, 12:31 PM
GUITAR1989's Avatar
Guitars & Cars >8D
Thanks for the help guys That is a killer link man! exactly what I needed to read. My vac advance can should be to at the parts store in a few hours
Carbureted Vortec giving rough idle, dieseling after cutoff TNshadetree Engine 17 04-17-2014 10:36 AM
Carbureted L31 Vortec Distributor Gear Melonized Iron vs Melonized Steel GUITAR1989 Engine 3 08-11-2012 07:46 PM
hei in vortec atcoed Engine 1 03-21-2012 06:36 PM
HEI timing stinky jinx Engine 6 05-31-2004 10:11 PM
HEI Timing Drifting?? 54 Chevy Engine 2 06-09-2002 12:17 PM
