carburetor - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2013, 01:54 AM
carburetor
does anyone know the float ajustments on a Rochester 17057253
Old 07-01-2013, 06:55 AM
Banned
this will get you started.
Old 07-01-2013, 09:53 AM
1/4" usually does the trick
Old 07-01-2013, 10:12 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
1976-'77 Olds 350 Q-jet, emissions calibrated. For an AT car despite the odd number. I believe it originally had 73 jets, 49K primary rods and CV secondary rods. Hot air choke.
Float level:
Start at 0.420, that should be right in the sweet spot. If it’s too lean, raise it some, but you shouldn’t need to go more than 0.375”.
If this carb is on a modified engine, you'll prollably need to tune it to give more fuel in the idle/off idle areas, as well as changing primary rods. The secondary side should be OK as-is if it's stock. You can check for full opening of the secondary air valve and throttle blades.
Old 07-01-2013, 10:44 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Lars suggests .375" - .400".
help with carburetor PGH Cutlass Hotrodding Basics 9 09-29-2011 01:32 PM
Carburetor medal5 Engine 3 09-29-2011 09:10 AM
New Old Carburetor Dougie Engine 4 11-08-2010 07:28 AM
carburetor cal=cutty Engine 1 10-01-2006 10:04 AM
Carburetor help 71gtx Engine 3 10-04-2003 11:56 PM
