carburetor cfm ratings
I have two 2-barrel carburetors. I will use one of them on a strong running 1965 chevy 283 engine in a '35 ford pickup. I would like to know the cfm rating for each of these carburetors which are:
Rochester 2 Jet, it has GM stamped on it and another number 7031714 Carter Model WGD-4078S Any information anyone can provide is appreciated. Thanks Rusty Duck |
Welcome, Rusty!
moving to engine forum.
Ontario Rodders |
neutral safety switch
I have a Lokar floor shifter with neutral safety switch on a TH350 transmission that will not allow the motor to start in reverse, 1st or 2nd gears, but it will start in neutral, park, AND drive. I know it is not suppose to start in drive, but since it works correctly in all gears except drive is the switch bad or is there some sort of adjustment that I can make?
1-3/16" venturi: 350 cfm 1-1/4" venturi: 380 cfm 1-5/16" venturi: 425 cfm 1-3/8" venturi: 435 cfm The small (1.25") bolt pattern 2G carb had a 1-5/32" venturi, a 1-7/16" throttle plate bore and was rated @ 280 cfm. It was used from '55-'71. Your carb is likely a '61 Chevy carb, w/small base and 280 cfm. The Carter is in the area of 320 cfm. NOTE: All cfm ratings for 2-bbl. carbs are @ 3"/Hg. 4-bbl. carbs are rated at 1.5"/Hg. |
Thanks Cobalt
I appreciate the info!
| SBC Factory Horsepower ratings? | Gearhead forever | Engine | 5 | 09-16-2007 07:08 PM |
| Connecting Rod Ratings | BringBackTheCamaro | Engine | 2 | 03-26-2007 07:19 AM |
| Factory Power Ratings | Blazin72 | Hotrodders' Lounge | 2 | 09-18-2006 06:28 PM |
| Octane ratings in USA | DannyW | Engine | 16 | 07-01-2005 12:32 AM |
| Inaccurate car manufacturors mileage ratings....what can be done? | TurboS10 | Hotrodders' Lounge | 10 | 01-07-2005 09:20 AM |
