fill it up with some muriatic acid and water, then drain it out ( '55 GM car anything has a drain plug ) with the drain plug. then put the plug back in, fill it up with diesel, then drain it out, then fill it with gas, it might run kinda bad on the first fillup due to the diesel, but you could flush some new gas thru it also to stop that.
