carburetor questions !!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2009, 09:26 PM
hello im looking for suggestions on what carburetor i should use for my sbc.....ok heres what i got
350 bored .080 over i think that makes it a 364
weiand stealth intake (idle to 6500 r.p.m)
brodix ik heads (180 intake runners 64cc combustion chambers)
my compression ratio should be between 9.5:1 - 10:1
comp cam magnum 292 .501
2800 to 3200 stall
th350 trans
4.56 gears
the car im putting this motor in is a 54 chevy 3500 pounds im guessing
this is gonna primarily be driven on the street but gas consumption is not an issue to me
any suggestions??????????
Old 05-07-2009, 10:03 PM
750 holley, edelbrock, or big quadrajet will work. Mostly will come down to personal preference. lots of threads on what is better. Each type has its own pros and cons.
Old 05-08-2009, 01:22 AM
327NUT's Avatar
Just a question, did the machine shop sonic test the block to see if it would safely take an .080 overbore? Thats gettin out there on a 350.
Old 05-08-2009, 06:43 AM
72fordlb's Avatar
BARN BURNING BIG BLOCK!
Yea! .80 over thats ALOT but if the block can handle it then good for it but i wouldnt have gone bigger than .60. but about the carb, alot of people use the holley 750 double pumper or if you can go bigger, but it really is just personal perference just like what sam bo3 said.
Good luck.
