carburetors - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2008, 07:52 PM
carburetors
I'm currently working with a holley 600 cfm street/strip carb. A guy on here yesterday told me i should go to a 750cfm for my engine set up. i was wundering if i whould have to get a hole new carb or if i could just put bigger jets in the one i have. I've never really worked on carbs, other than pullin the bowls, floats and needles for cleanin purposes can anybody tell me if this is possible and mabey how to do it. the part # on my carb is 80457. Thanks
Danny
Old 06-19-2008, 08:09 PM
You would have to go to another carb. The jetting of the 600 would make it to rich.
Old 06-19-2008, 09:20 PM
cowbay's Avatar
Get another carb and if you want to save some money ebay the old carb.
Old 06-19-2008, 09:54 PM
Danny
Without knowing what engine is and how it's set up it's impossible to say anything about carb size other than 600 or 750 relates to air flow capability which is related to venturi and throttle bore size. This has nothing to do with jet sizes which control main well fuel flow which is one contributing element that establishes the fuel to air mixture ratio. One could assume that a bigger air flow carb would also require larger main fuel jets, but life and carbs aren't that easy. The rest of the engine such as displacement, compression ratio, operating temperature, spark lead, type of cylinder head and piston crown shape, cam timing, type of intake manifold, the carb itself, type of exhaust, even the air cleaner assembly are some of the many elements that will affect jetting.
Bogie
Ever deal with Stahle performance carburetors joe k Engine 5 03-06-2006 01:50 PM
What is "white stuff" in carburetors? newchevyman Engine 7 08-11-2004 08:37 PM
Help!- Need Fuel assembly ideas for 2 four-barrell Edelbrock Carburetors johnbyholt Engine 1 01-29-2003 04:53 PM
predator carburetors? mustang66maniac Engine 7 12-09-2002 08:12 PM
Carburetors, electric or manual choke? 66StangBoy Engine 5 11-07-2002 05:30 PM
