Great job . How hard was the base plate to fabricate? What did you use?
Most of these eaton blowers are plentiful and cheap. Nice to see people using them. The edelbrock carbs sound like a good idea to me too. |
It looks like we left the camera at the in-laws tonight so I will try and remember to snap some pics in a few days.
| The Following User Says Thank You to xxllmm4 For This Useful Post: | ||
ap72 (03-02-2013) | ||
When did Buick make a Bonneville??
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
About the only thing you really need to look at are the rotors/case. If they are scratched toss it. The most common problems are as follows.
1. Plastic coupler inside the snout wears out, causing a clunking sound. New ones go from $15-25 always replace them if you have the blower opened up. 2. Front snout bearing, then second snout bearing. Easy to replace and cheap. You just need a shop press. 3. Rear rotor bearings. Depending on the model you may need to drill and tap the blower housing, add zerk fittings and pump the bearing out with grease. not hard to do. Bearings cost about $3-4 ea. 4. Front rotor bearings. These can be difficult to replace. Sometimes the housing will break when they are pressed out. 95% of the time these bearings are fine and don't need to be touched. |
64nailhead (03-02-2013) | ||
Are they making a better Pred carb now? I know yrs ago they were hard to get dialed in and when you did they kinda had a mind of their own on how they were going to idle. This sounds like a cool build. Friend of mine had a Grand Prix, 3.8 work car he played with. It had alot of miles, pretty rough looking, but wouyld run high 12's slicker than hell. You ought to have seen some of the looks he got when he would smoke a newre Mustang.
Ohh yeah one more thing, the snout oil seal, they wear out and start to leak. They make 2 kinds. A rubber seal and a viton. I don't recommend the viton, its harder and will actually wear a groove in the steel shaft. The rubber also seals better on worn parts.
The seals are also off the shelf parts. You just need to know the numbers and where to find them at industrial supply houses. |
Thats awesome !!!
Your two threads, same subject matter, have been merged. If you don't have questions in a thread, consider posting in the projects forum, but don't expect answers to any questions, it's a show n' tell forum.
| 650 cfm mainbody on a 750 cfm baseplate? | darkostoj | Engine | 5 | 09-05-2008 07:38 AM |
| carburetors | eatonde | Engine | 3 | 06-19-2008 08:54 PM |
| dual superchargers | kwopper07 | Engine | 12 | 05-02-2008 01:58 PM |
| Something different: dual centrifugal superchargers | StevenC | Engine | 14 | 08-23-2005 10:10 AM |
| 1200 Bhp '74 Corvette with dual superchargers! | TNTster | Hotrodders' Lounge | 3 | 10-04-2004 09:18 AM |
