383 @ 6K @ sea level
0# 665 cfm 2# 755 cfm 4# 845 cfm 6# 936 cfm 8# 1026 cfm 10# 1117 cfm 12# 1207 cfm 14# 1298 cfm 16# 1388 cfm 18# 1479 cfm 20# 1569 cfm At 9.3 SCR, 10 lbs of boost will put the effective final static compression ratio at 15.5 which may be about the limit for E85. Don't take this as the final word on the subject, just as a starting point to dial from. You may find a way to run a much higher EFSCR. Last edited by techinspector1; 11-25-2008 at 10:09 PM. |
Thanks for the info Tech, I think I'm going for twin Predators. They are self adjusting so it shouldn't be a problem to go too big.
I'm actually surprised more people haven't done this. I got mine at the u-pull it for $70ea. Rebuilding them is easy, all the bearings and seals are off the shelf parts and cost about $20 if you shop around. The most expensive part so far has been the bottom pulley at $170. I will take some pics along the way but right now our business has been really busy. Jordon |
Those huffers were designed to move dry air. Better make sure the seals and such are gonna be ok with gasoline or E85 or whatever you plan to run.
I hopefully got it covered. Form some of the message boards I have read quite a few people have used them with carburetors and no problems. Too be on the safe side I got new rear bearings with seals, the bearings are standard rear alternator bearings for GM cars, Been soaking them in E85 for the past week with no change in the seals. I have also been thinking about putting zerk fittings on the rear bearings but their only $3.50 ea so I'll probably call it good.
I have been planning this for months, making drawings, figuring the easiest way to make parts out of stock sized steel. I have even been dreaming about superchargers. I even have a note pad on my night stand
Did you ever complete your project? Pics? I bought a M90 a couple of years ago to put it to my 350. Got side tracked with motorcycle stuff. Trying to get back on track with this project. I have some ideas, but looking for others that have done this and how.
They came off a T-Bird. Yes I did get it running and it ran very very strong. I just could not bring down idle enough to make it workable on the street with the Predator Carbs.
I still have it and may put it back together one day when I get some extra cash for some carburetors. |
any photos of the intake manifold? Consider possibly just using one Predator carb?
What is your target power output? It's probably within the reach of one predator carb. |
| 650 cfm mainbody on a 750 cfm baseplate? | darkostoj | Engine | 5 | 09-05-2008 07:38 AM |
| carburetors | eatonde | Engine | 3 | 06-19-2008 08:54 PM |
| dual superchargers | kwopper07 | Engine | 12 | 05-02-2008 01:58 PM |
| Something different: dual centrifugal superchargers | StevenC | Engine | 14 | 08-23-2005 10:10 AM |
| 1200 Bhp '74 Corvette with dual superchargers! | TNTster | Hotrodders' Lounge | 3 | 10-04-2004 09:18 AM |
