carpet in a 1949 chevy pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2011, 04:15 AM
can some give me some pointer on how to install the carpet in a 1949 chevy pickup.
thanks
Old 10-29-2011, 06:11 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I would pull the seat out..remove the boot around the shifter (floor shifter) and the door sill plate as well as anything else that may be attached to the floor..then lay the carpet in and work it around until it lays down nice and then re-install the seat and anything else that may have been removed..
Sam
Old 10-29-2011, 07:04 AM
DanTwoLakes's Avatar
Wiki Edits: 22
You should also put down any sound deadener material you plan on using and put down some kind of padding, whether it is jute or polyfoam. You can then use the padding as a pattern to cut your carpet about 3" bigger than your padding which will make your carpet more manageable. After that, trim it down to size and put the truck back together.
mounting the cab on a 1949 chevy pickup tbrown8338 Body - Exterior 20 02-16-2016 08:10 AM
1949 chevy 3100 pickup alv55 Introduce Yourself 1 09-22-2010 03:30 PM
1949 chevy pickup cruiser 49 chevy Introduce Yourself 5 03-19-2007 09:03 AM
1949 chevy pickup sumdaymyownshop General Rodding Tech 3 02-14-2005 08:20 AM
1949 chevy 5 window pickup shrades General Rodding Tech 2 08-04-2004 07:11 PM
