Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Carpet installation.. any tips, pointers, etc?
Old 03-11-2012, 06:58 PM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
I would do this in three pieces. Cover the tunnel first, and then each side from front to back as a separate piece. If you don't want to bind the edges next to the tunnel, simply turn them under and sew them down, or if the carpet is nylon, you can heat the edges with a flame and melt the edges, assuming the carpet is black or at least dark.
