carpet problem on '32 roadster - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2008, 07:52 PM
I just installed some carpet in a '32 ford, I can't get how to install it on the trans. tunel. do you split it down the middle and sew in a V shape? the carpet has a rubber back on it like indoor outdoor carpet. The tunel is about 2ft. long and about 8in. high at the firewall, and molds into a flat floor. can someone help me out? thanks///Dan
Old 05-25-2008, 08:00 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
I could offer some suggestions if you can post some pixs please.
R
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 05-25-2008, 08:01 PM
79C10's Avatar
Viva la Migra!!
Try this. Take a piece of string , lay it across the front part of the tunnel hump. mark where it touches the floorboard , then lay it out straight and measure the length from mark to mark . Then you go back to the flat spot and measure the width . Then measure the length. Flip your carpet over and 'lay out' your measurements. Length , front width and back ( narrow )width. It sounds like you'll have a pie shaped piece , but it might just work. I wish I could be there to see what you're talking about , but this is my best attempt at helping you.
Mike
Old 05-25-2008, 08:49 PM
DanTwoLakes's Avatar
Wiki Edits: 22
You will not get one piece of carpet to cover the whole thing. The tunnel gets covered with a separate piece of carpet, which is the first thing you cover with the carpet. Then you need to cut out around the base of the tunnel and bind the edges of the carpet that butt up next to the tunnel. Look at this picture from Krist Kustoms. CLICK HERE Click on the picture on the lower left side, and you'll see what I mean.
32 roadster chassis spark Hotrodders' Lounge 4 08-31-2007 05:06 PM
32 Roadster Project - Worth it? TexasSpeed Hotrodders' Lounge 3 07-05-2007 07:43 PM
Softtop for 32 Ford Roadster Fonti Body - Exterior 0 03-28-2006 01:44 AM
junkyard rearend options for '32 roadster? MattM Transmission - Rearend 7 12-10-2005 11:23 PM
awesome deal on 32 roadster body deuce_454 Body - Exterior 1 05-28-2003 01:09 PM
