Carpet and Seat Suppliers - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2008, 08:58 PM
I am working on the interior of a 1963 Chevy Pick up and want more color options for the carpet and seat; more options than what LMC have to offer, etc.
Any suggestions out there on who may be a good source for variety?
Thanks
Andy
Old 05-20-2008, 09:01 PM
Wiki Edits: 31
I used These guys for my '51 Chevy, but I have yet to install the kit.. I can say, the quality is top notch and there customer service is excelent.. they will have the correct pattern for your truck seat so fitament should not be a problem
Old 05-20-2008, 09:26 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Check here for carpet CLICK HERE As far as the seat goes, why not have it done by an upholsterer? Truck seats are as simple as they come, and are not expensive to have re-done. Check out this thread: TRUCK SEAT
Old 05-21-2008, 08:03 PM
Thanks for the help
Thanks guys for the ideas. The seat in the 1963 is worn as though it is older than original. There is a significant dip in the springs in the driver position. I will look into the first link, but also consider a seat only and upholster to finsih the job.
Old 05-22-2008, 06:03 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
On the 60-66 carpets; there are 2 floor types. low tunnel for 3 speed & auto, and high tunnel for floor shifted 4 speed truck trans. Make sure the supplier offers the correct one. 10 years ago, it took 3 shipments/returns, to NEVER get the right one for mine. The supplier had no freaking idea on the 2 styles! I ended up buying the carpet from a local uph shop...one order is all it took. They also did my seat from scratch with material they had samples of.
Old 05-22-2008, 06:16 AM
Dusty82's Avatar
Last journal entry: The Chevy Bench Seat - Part 52
If your seat frame isn't bent, twisted, tweaked, or rusted so badly that it's unusable, there's no need to get a new one unless you're after something more modern. Your old frame can be repaired by replacing some of the worn out springs. DanTwoLakes has covered this in a thread about rebuilding a bucket seat frame in this thread:
http://www.hotrodders.com/forum/buck...ir-117899.html
Your bench seat frame won't be too different, and the shop that does the seat covers should be able to do the frame repair for you with no problems. A guy in my upholstery class is restoring a '67 Chevelle, and he went so far as to strip the seat frames of all upholstery, foam, and springs, then he took them down and had them sand blasted and powdercoated. He then replaced all of the springs in class and started from scratch. The powdercoating (I'd have just painted them with a rattle can) was bit of overkill, I know, but he'll never have a problem with those seat frames again.
Old 05-22-2008, 07:09 PM
I'm in love with this carpet:
http://www.yourautotrim.com/80wideozite.html
It stretches ALOT. It looks nice. It has no backing so you can trim it to a nice edge without a sewed on edge. It's 80 inches wide. It's cheap.
Installed:
Larry
Old 05-22-2008, 07:45 PM
Wiki Edits: 22
Yes, you can put this in your vehicle without binding it because it is a synthetic that does not fray on its cut edges. There is another product called Spectropile which is just like this. Both of these items are intended to be sewn into the bottom of the back of the front seat of production line cars. If you kick it with your feet while sitting in the back seat, you won't do any damage to the bottom of the front seat. There is nothing wrong with using these two products as carpeting if you're on a budget, but, if you do, bind the edges to give it a finished look. Any carpet, or anything used in place of carpet, will look better if it is bound at the edges. These two products are as easy as pie to bind because they are very thin. JMO.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Power Seat Wiring Info Needed- Mid 70's Chevrolet/Chevelle LongTom Electrical 1 02-06-2007 01:36 PM
Carpet places BarryK Interior 5 01-27-2005 04:14 AM
Can not figure out how to remove rear seat. HotRodMan Interior 7 04-26-2004 07:27 PM
How bad did I get Ripped? (carpet installation) Alexander Interior 13 01-23-2004 07:24 PM
