Carpet? What, where, how??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2008, 10:23 PM
chevy3600's Avatar
http://community.webshots.com/
I will be starting my interior soon. I have already covered it all with Second Skin vibration dampener and need to lay some carpet. What is the best carpet,, cut pile, or loop pile? How to measure, where to buy and any other tips to stay out of trouble.
Old 12-09-2008, 09:53 AM
DanTwoLakes's Avatar
Wiki Edits: 22
There are all kinds of places online to get automotive carpet. Here is a good link to Auto Custom Carpets. CLICK HERE
Carpet is a personal choice. Cut pile is what the manufacturers use almost exclusively now. 80/20 loop carpet is basically the same carpet as cut pile, only with the ends of the loops intact. In general, loop carpet resists holding dirt a little better than cut pile, and is slightly easier to clean. You don't say what vehicle you are putting it in, but if you can find a carpet set already cut for your car, it will save you a lot of time cutting and fitting.
If you want to do it yourself, Automotive carpet is sold by the yard and comes 6' wide, which is plenty wide to fit almost any vehicle. All you need to know then is how far it is from the firewall to a spot under the rear seat. If you will be carpeting the firewall, add that much more. In other words, if the distance from the firewall to under the rear seat is 60", and the distance from the floor up the firewall is 24 ", you need 2 1/2 yards of carpet. If you have a transmission tunnel that sticks up quite a bit, you will need to cover that separately first, then cut the carpet around it, and bind the edges where you cut it to fit around the tunnel. If that's the case, add the distance from the firewall to the end of the tunnel to your measurements. If that's 24", added to the other measurements, you'll need 3 yards.
Old 12-09-2008, 10:09 AM
302 Z28's Avatar
What Dan said. FWIW I found some carpet that did not have the thick underlay that traditional carpet has. My main purpose going with it was over the trans tunnel. I had no way of getting the carpet sewn, nor did I want to. This carpet is the type you see glued to the bottom of door panels. It must be glued down to the floor to work right. Due to the fact that it does not have the heavy backing it follows compound curves very well. It will form completely over and around the trans tunnel with no seams or wrinkles. Granted it is not as durable as traditional carpet, but my car is not driven that much anyhow.
Vince
Old 12-09-2008, 10:40 AM
chevy3600's Avatar
Thanks guys
Questions:
Dan
1) I have bought carpet for home and business and had the edges bound by the carpet company. Is this where you had your carpet bound?
Vince
2) I like the idea of just pressing the carpet down on the trans tunnel to make it fit but if necessary to glue down, I am using 2nd skin on the floor and wonder if gluing the carped down would work.
Old 12-09-2008, 10:46 AM
302 Z28's Avatar
Originally Posted by chevy3600
Thanks guys
Questions:
Vince
Yes it would, on mine I first applied a ceramic sound/heat insulating layer. Then on top of that I glued down 1/2" double foil faced jute. I then glued the carpet to that. If I ever have to remove it, it will be a mess.
Vince
Wiki Edits: 22
In general, automotive carpet is much more pliable and has less backing than carpet that goes in your house or indoor-outdoor carpet because auto carpet needs to mold itself into odd shaped areas.
Automotive carpet can generally be formed with the help of a steamer. This thread CLICK HERE shows the type of steamer I'm talking about. One other tip: Be careful how much padding you put under the carpet. This can raise all kinds of problems for doors closing.
Old 12-09-2008, 10:54 AM
Wiki Edits: 22
Thanks guys
Questions:
Dan
I bind my own carpet with an industrial sewing machine. Here's a thread CLICK HERE that shows a set of floor mats (for Vince's '34) being bound. It's the same process for a larger piece of carpet. The reason I bind it myself is to be able to incorporate the fabric from the rest of the interior to be used as binding.
Old 12-09-2008, 10:57 AM
Dan knows more than me, he does it for a living. I ordered my carpet from Ron Mangus and I also bought his carpet install video. It helped me alot.
There are photos in my album.
Kirk
Old 12-09-2008, 11:58 AM
chevy3600's Avatar
Dan: I don't believe my cleaners will let me borrow their steamer. I could use my wife on one of her bad days.
Last edited by DanTwoLakes; 12-09-2008 at 12:42 PM. Reason: Violation of guidelines. Please see: general board guidelines.
51' GMC Truck carpet? jimmy1 Interior 1 11-06-2008 12:07 PM
New Carpet for 78 camaro 406chevelle Interior 3 03-01-2007 09:23 PM
replacing carpet montea Interior 11 10-30-2006 06:51 PM
Molding Carpet WakBordr7387 Interior 6 09-19-2005 02:43 PM
How bad did I get Ripped? (carpet installation) Alexander Interior 13 01-23-2004 07:24 PM
